 Post subject: copyto / moveto
PostPosted: Sun Mar 04, 2012 11:37 am
jorge i have registry tweaks for adding the copyto / moveto entries to the rightclick context menus. it works great never had a problem with it except for trying to use it on the shelf. i rightchilck an item in one of the tabs and go to either copyto or moveto, click on say backups - utorrent to expand it so i can pick a subfolder and the dialog closes out and the item i was trying to move just disappears. any idea on why this behavior is happening?
copyto/moveto reg files http://min.us/mvzsYBYwa#1o
 Post subject: Re: copyto / moveto
PostPosted: Sun Mar 04, 2012 2:05 pm
I have the same problem and I had reported it here
viewtopic.php?f=2&t=4542&start=15
Waterworld
PostPosted: Sun Mar 04, 2012 9:03 pm
Shelf context menus are set to close automatically whenever you click outside the menus. Because the Send To/Copy To menu is not technically part of the Shelf context menu, any click on it is interpreted as a click outside the Shelf context menu and these therefore close automatically.
PostPosted: Sun Mar 04, 2012 9:17 pm
o.k. is there anything i can do on my end to change that behavior?
PostPosted: Sun Mar 04, 2012 9:27 pm
Nope, sorry...
And with v12.2 about to be released, I don't have time to look into this right now either... :cry:
PostPosted: Sun Mar 04, 2012 9:45 pm
Nope, sorry...
o.k. if you get to it great, if not no biggy. just thought i'd see. thanks jorge.
Users browsing this forum: Apple [Bot], GPT [Bot] and 58 guests
