 Post subject: Nexus dock crashing
PostPosted: Fri Jan 06, 2012 6:02 am
I just recently installed Nexus dock on my pc running windows 7 Ultimate 64-bit and it crashes every so often. When it does I can't seem to restore it unless I restart the computer. Is there any way to get it to come back without having to restart the computer? Any answers?
 Post subject: Re: Nexus dock crashing
PostPosted: Fri Jan 06, 2012 6:46 am
First of all, Nexus should not crash, so it would be nice to figure out why it's crashing on your system, see if it's something I can fix. :D
Anyway, when you say 'crash' do you mean a real crash with an error message and all (in which case, what is the error message?) or a freeze?
One thing you can do to avoid having to restart your computer is opening up the Windows Task Manager, going to the processes tab, selecting 'nexus.exe' and then clicking the 'End Process' button. You should then be able to restart Nexus normally.
Also, if the crash happens again, when you go to the Windows Task Manager to terminate the process, please first write down Nexus.exe CPU and memory usage, and then pass on that information to me.
Users browsing this forum: No registered users and 47 guests
