 Post subject: Green Saver Options in Nexus Dock
PostPosted: Mon Dec 19, 2011 10:42 pm
Hi,
please add options green saver in effects tab; I would like to have the possibility to disable the reflection effect when I use notebook in battery mode; thanks!
Best Regards and thanks for your splendid work WinStep Team
 Post subject: Re: Green Saver Options in Nexus Dock
PostPosted: Tue Dec 20, 2011 11:46 am
Why? Icon reflections are cached (unless the icons are animating), so this is a non-issue.
PostPosted: Tue Dec 20, 2011 11:53 am
Hi Winstep,
do you mean that when the reflection is active it doesn't decrease the consumption of the battery of notebook?
PostPosted: Tue Dec 20, 2011 12:05 pm
If you are not using animated icons (which must recalculate the reflection for each frame) then I would say CPU usage is meaningless. The reflection is calculated once and then the same cached reflection image is used until there is a change in the source icon.
Anyway, you can easily toggle icon reflections yourself, either from the Effects right click context menu or the Appearance tab in Preferences.
PostPosted: Tue Dec 20, 2011 1:52 pm
Hi Winstep,
I spoke of the option "Animate icon reflections so icons appear to be reflecting on water"; yes I know that it can to be disabled but it would be useful an option that allows the auto disable in mode battery, thanks!
Users browsing this forum: Bing [Bot] and 49 guests
