 Post subject: Nexus settings backup problem
PostPosted: Sun Dec 18, 2011 5:30 pm
Is there any way to backup nexus's settings?
When I clicking on Backup button in advanced preferences nothing happens. There is no any backup in the Backup folder in Documents\Winstep\Backup.
From which files I need to make copy for manual backup, because backup button is not working?
I use Nexus 11.10 on Windows 7 x64.
 Post subject: Re: Nexus settings backup problem
PostPosted: Mon Dec 19, 2011 3:55 am
When you click on the Backup button in the Advanced tab of Nexus Preferences, you are supposed to get the normal Windows file dialog asking you to name your backup and select a folder to save it at. Then you get the small splash window saying 'Please wait... backing up settings'.
I just tried it here, also on a Windows 7 x64 system, and it's working as it is supposed to.
Is anyone else reading this also having trouble with this function?
RagingDemon, are you using any other Windows customization utility that might interfere with the Windows standard file dialog? What happens if you click the Restore button, do you get the Open file dialog or nothing happens either?
PostPosted: Thu Dec 22, 2011 1:26 pm
When I click on Restore button I'm getting the OpenFileDialog to choose Wbk file, but when I click on Backup button nothing happens, there is no SaveFileDialog.
I realize that the problem is in my Windows, not Nexus, SaveFileDialog not appears in some other programs too.
Does anyone know how can I fix this?
BTW, I found way to backup my Nexus settings manually.
Users browsing this forum: No registered users and 54 guests
