 Post subject: Shift+A problem
PostPosted: Sat Dec 03, 2011 8:20 pm
Hi,
Not sure if this is a Winstep problem or Windows, but it seems to have started since installing Winstep. Whenever I am typing and use Shift+A to capitalize a word the curser disappears and I have to click where I am typing to start again. This is very annoying if you forget and have to start over. I have tried disabling Hotspots keys that have that combination but that doesn't work either. If you can help, thanks....
Jetstream
 Post subject: Re: Shift+A problem
PostPosted: Sat Dec 03, 2011 10:15 pm
there is no such thing as shift+a to capitalize words. you press and hold the shift key and then press the letter you want capitalized.
PostPosted: Sat Dec 03, 2011 11:26 pm
Wrote that wrong, I know not to shift+A capitalize. What I meant was Shift to capitalize the letter A, that's when the curser disappears. Sorry for the confusion...
PostPosted: Sun Dec 04, 2011 12:42 am
My guess is that you assigned SHIFT + A as they hot key to *something* (either on purpose or by accident) and then forgot about it.
Are you running Winstep Xtreme or Nexus Ultimate?
PostPosted: Wed Dec 07, 2011 11:10 am
I'm running extreme, and I checked all the hotspots and disabled all the shortcuts, unless I missed one somewhere.
PostPosted: Wed Dec 07, 2011 2:12 pm
ok then more than likely you somehow created a keyboard shortcut for something else. i did a search to see if there was anyway to get windows to list all of the keyboard shortcuts a user has and could not find anything. maybe someone else here will have better luck than i did, or know how to do it. in the mean time i'll ask on a couple of forums i belong to if anyone there knows.
PostPosted: Thu Dec 08, 2011 10:08 pm
First exit NextSTART. See if the problem persists.
If so, exit WorkShelf. See if the problem persists - if it does, it's not caused by Winstep Xtreme.
If not, let me know and we'll continue troubleshooting from there.
PostPosted: Fri Dec 09, 2011 10:51 am
The problem appears to be with Workshelf, when I stopped it the problem went. It didn't make any difference when I stopped Nextstart.
**Update**
found the problem with one of the modules, thought I had checked them all. Seems ok now. Thanks....
PostPosted: Fri Dec 09, 2011 9:01 pm
There you go, glad you found the culprit. :D
Users browsing this forum: Apple [Bot] and 55 guests
