 Post subject: Can I delete something permenently from a menu?
PostPosted: Fri Nov 11, 2011 8:24 am
So i'm browsing my files and pictures using nexstart menu coz its really convinient and comfortable. I also arrange things this way. So i wanted to delete somthing i right click it then press delete or drag it to recycle bin or recycle module.....
Which ever the case i can't delete it permenently without emptying the recyclebin? Any hints?
one other thing the recycle bin module doesn't show the full icon unless i access the original recycle bin. (doesn't work when you refresh). Is there anything i can try?
Users browsing this forum: Majestic-12 [Bot] and 36 guests
