 Post subject: Disable Bottom Edge Activation
PostPosted: Tue Nov 01, 2011 1:06 pm
I have my dock on the bottom but I don't want it to pop up unless I bump the top screen edge. Right now it does pop up when I bump the top screen edge BUT it also pops up when I bump the bottom screen edge! :(
On the Position & Behavior tab I have "Dock to screen edge" checked and I selected "Bottom" from the pull down menu. Then on the same tab, I clicked the Advanced button and chose "Bump Top Screen Edge."
I've tried checking "Disable edge activation," but it still pops up when I bump either the top or bottom edge. :(
On the "Advanced" tab where it says "Miscellaneous advanced options" I clicked the Advanced button and unchecked "Pop up dock on mouse over," but it still pops up when I bump either the top or bottom edge. :(
Help!
*Edit: Just updated to the most recent version 11.06.0968 hoping that might fix it but the problem still exists. :(
P.S. I do like the fact that the focus now returns to the window that had it :D , but the fact that the dock keeps popping up when my cursor goes to the bottom is driving me nuts!
Users browsing this forum: Google [Bot], GPT [Bot] and 65 guests
