 Post subject: road map ?
PostPosted: Sun Oct 30, 2011 11:33 pm
hello it's time for me to renew .... but i would like to see a road map. at the moment i don't see any advantages to renewing do you have a rode map ? weeks months years would be nice to see what's going on thank you
 Post subject: Re: road map ?
PostPosted: Mon Oct 31, 2011 12:56 am
You know what the problem of road maps is when used to make decisions like that? Road maps are not much more than exercises into futurology. Even though nobody can predict the future, if you later happen to go astray for one reason or the other, customers still have this habit of holding you to your 'road maps'. And sometimes they even get mad if they feel they are waiting too long for a feature they want.
So, I don't like giving road maps. Instead, I ask the user to open the history files for Nexus or WorkShelf or NextSTART and judge the possible future by what has *actually* been done in the past.
My advice to you is thus to renew on 'faith' now, or renew only when you see a new release that interests you enough. One thing is for sure: you can't go wrong by doing the latter. :D
PostPosted: Mon Oct 31, 2011 4:37 am
This said, and after thinking for a little while, I can give you a broad idea of what lies ahead, without getting into much detail:
* Multiple Shelves (tabbed docks).
* Vertical Shelves.
* Lots more modules/widgets.
* Winstep native theme builder.
PostPosted: Tue Nov 01, 2011 11:54 pm
i will renew on next beta ... when ever that is
PostPosted: Tue Nov 01, 2011 11:56 pm
where can i find the history files. thank you
PostPosted: Wed Nov 02, 2011 12:08 am
In the C:\Program Files\Winstep\ folder (or C:\Program Files (x86)\Winstep\ on a 64 bit system). There's one for NextSTART and another for WorkShelf.
PostPosted: Wed Nov 02, 2011 12:35 am
* Vertical Shelves.
i been hang out for
* Vertical Shelves
Users browsing this forum: Google [Bot] and 64 guests
