 Post subject: Nextstart Menus will not change theme
PostPosted: Fri Oct 28, 2011 12:53 pm
I seem to have lost the ability to change the Nextstart Menu theme.
I have Winstep Theme Integration checked in both Nextstart and Workshelf. I have Workshelf checked to always use the default menu theme. I have both set to use Windows 7 Extreme but the Menus are stuck in Acrylic7. Shelf, Taskbar & Nexus docks all display the correct theme.
Windows 7 x64 w/latest updates and Winstep 11.6
 Post subject: Re: Nextstart Menus will not change theme
PostPosted: Fri Oct 28, 2011 5:04 pm
What happens if you change the theme in NextSTART instead of WorkShelf?
Also, check the hotspot associated to the NextSTART menu (usually hotspot #0), make sure you didn't hard code a specific theme to it.
PostPosted: Sun Oct 30, 2011 2:22 pm
No difference. It still uses the Arcylic 7 menus for the hotspots.
Where would I find that setting? I don't see it under Hotspots or in the Menu Editor
PostPosted: Sun Oct 30, 2011 7:47 pm
In the Hotspots tab of NextSTART Preferences.
Select the Hotspot associated to a specific menu, click the Edit button and move through the Hotspot Wizard until you get to the page that allows you to specify 'Do you want to attach a specific theme to this menu?'.
It should be set to 'Default'.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 67 guests
