 Post subject: Shelf Icon - Increase Size
PostPosted: Tue Oct 18, 2011 8:29 pm
I just purchased Winstep Xtreme and I can't wait for my unlock code to get going off the Free Version. I just had a few questions I was hoping to get answered while I wait for my unlock codes...
One is, when I move across the Shelf, I don't know if it was originally and Apple Feature, but I love how the active Icon increases in size and the rest decrease and spread out across the shelf. Is there a way to do this on the Taskbar as well?
I did not see this anywhere in the FAQ's but is there a way to edit or adjust the Context Menus (right click menu) with any of the programs in the Xtreme Suite?
And last question I have is...I currently using Dragon Naturally Speaking by Nuance. When I have Dragon loaded, I can say "Load Start Menu". Can I still do this with your program? Is the command any different?
Thanks for your help and I really look forward to getting started with my new software!
Bob
 Post subject: Re: Shelf Icon - Increase Size
PostPosted: Tue Oct 18, 2011 8:41 pm
Hi Bob! :)
No, sorry, the NextSTART taskbar is pretty much static (aside from some fade in/fade out effect you can apply to the tasklist buttons). You can, however, use a dock as a taskbar replacement and use that instead.
No, context menu options are static. Under WorkShelf, however, you can opt for 'simple' right click menus when you click on shortcuts (i.e.; context menus that do NOT display all those options also available in Explorer right click menus): WorkShelf Preferences -> General -> More Options -> Context Menus section.
Yes, the command is different, since, under Winstep, pressing the WIN key will still bring up the *Windows* Start Menu, and this is by design.
This said, if Dragon Speaking allows you to assign a sequence of key presses to a voice command, then you're home free: you can assign a hotkey (e.g.; CTRL+ALT+1) to hotspot 0 in NextSTART (the hotspot responsible for activating the NextSTART menu) and have Dragon simulate pressing that hotkey when you give it a certain voice command.
PostPosted: Thu Oct 20, 2011 10:35 pm
Thank you for the detailed response to my question. As you can imagine it's going to take a couple of days to go through this and start to apply.
Bob
Users browsing this forum: Apple [Bot] and 14 guests
