 Post subject: Applying themes to multiple user profiles.
PostPosted: Mon Oct 17, 2011 12:28 pm
Hi Guys.
I am very new to Winstep and have been playing around with downloading new themes. My aim is to be able to customise and maybe design my own theme (eventually)!
I just wondered if it is possible to have one custom theme and apply it to multiple profiles?
I dont mean that a new user would be able to download the same theme as is on my profile, after they have set up their user account.
Is it possible as an administrator to set a theme as default and then any user profile that is created after that will automatically have this theme?
I have tried researching if you can or not. There was an answer in the FAQ's that gave me hope, but am not sure if it what I am after.
I hope that I gave explained it well enough for you to understand what I mean, any help would be greatly appreciated.
Thanks in advanced
 Post subject: Re: Applying themes to multiple user profiles.
PostPosted: Mon Oct 17, 2011 7:36 pm
Even though settings of the application are per-user, the actual theme data files are shared between *all users*.
This means you can have user A using theme X and user B using theme Y (or both using theme Y, for instance).
Provided none of the users deletes the actual theme data (bitmaps, configuration files, etc...) you shouldn't have a problem sharing the same theme between multiple users - you just need to install the theme once and it becomes available to all users.
Users browsing this forum: Google [Bot] and 63 guests
