 Post subject: Default behavior of right click on tasklist button?
PostPosted: Tue May 25, 2004 9:07 pm
----- Original Message -----
To: <WS2K-Beta@yahoogroups.com>
Sent: Friday, April 16, 2004 4:58 PM
Subject: Re: [WS2K-BETA] NextSTART v3.1 at Download.com
> After reading the review, I THINK that what they are talking about in terms
> of the taskbar is that the standard Windows right-click menu from the
> Windows taskbar doesn't exist in the same way as it does in Windows.
> Instead, you need to know that right-click minimizes, alt-click (or
> double-click?) closes, etc.
Ok, after the review in Download.com:
http://download.com.com/3000-2341-10281 ... ?tag=sptlt
do you guys think that the default NextSTART behavior when right clicking on a task tile should be to display the tasklist context menu (like Windows does) OR the current default behavior (right-click minimizes application)?
On one side, displaying the context menu might be easier for new users - on the other side it would be equivalent to 'hiding' what I think is one of the most handy features of the NextSTART tasklist. Notice how even the reviewers failed to notice that you can customize what happens when you click on a tasklist button.
PostPosted: Fri May 28, 2004 6:12 pm
Personally I rarely use any button but the left mouse button on task tiles.
Once in a while I use the right mouse button to minimize it. I like it the way it is. <shrug> my 2 cents. :)
Users browsing this forum: Majestic-12 [Bot] and 43 guests
