 Post subject: Where oh where is the Net Meter?
PostPosted: Sat Aug 20, 2011 9:07 pm
Hi Winsteppers:
I have installed Nexus, and at present, it shows the default icons. A Tip has popped up concerning the Net Meter.
That looks neat, 8) but I do not see the Net Meter in the set of default icons. I looked it up in the Help, and there is reference to it and all that it can do. However, I do not see where it tells me how to bring it in to the dock,so that it will pop up with such items as The Start Menu, Firefox, Thunderbird, the Clock, the CPU Meter, the Recycle Bin and Capture Desktop.
Have I no Net to Meter? Or is there a simple way to put it in wth its peers?
All suggestions will be gratefully received.
Pdr
 Post subject: Re: Where oh where is the Net Meter?
PostPosted: Sat Aug 20, 2011 10:31 pm
Did you try right-clicking the dock -> 'insert new dock item' -> 'module' -> 'net out'/'net in'?
PostPosted: Sat Aug 20, 2011 11:02 pm
Thanks kutagh. I didn't quite know where to look. And now they are happily metering away! :)
Pdr
Users browsing this forum: Google [Bot] and 25 guests
