 Post subject: Nexus crash after windows standby or hibernate
PostPosted: Tue Aug 09, 2011 10:00 am
Hi,
I tried to search if there already was any information about this problem, but I couldn't find anything. So sorry in advance if I missed anything.
Most of the time, when I come back from windows standby (or hibernate) mode, Nexus crashes. More precisely, if I put the mouse over the docks, the cursors changes into the hourglass, as if the dock was loading, but it nothing further happens. And if I try to clic, then I have a windows error message telling me that the program is no responding, and I can force it to shutdown. I then have to reopen nexus in order to have it back. This problem occures on two different computer (laptop and fix computers).
Is it a known bug? Is there any way to fix it? It is aspecially anoying with my laptop, since it occurs most of the time when I open it after it was closed for a even a short time...
Thanks in advance for your help!
 Post subject: Re: Nexus crash after windows standby or hibernate
PostPosted: Tue Aug 09, 2011 5:56 pm
Are you sure you're running the latest version of Nexus (v11.6)?
PostPosted: Tue Aug 09, 2011 7:51 pm
Yup, version 11.06.0968 to be precise.
But I'm not sure anymore, was this version released in the last few days? Because I'm not absolutelly sure if the problem has occured in the last days, so if the update was very recent, this topic might be refering to a solved problem. But I'm pretty certain the problem has occured at least in the last two weeks or so...
PostPosted: Wed Aug 10, 2011 2:31 pm
v11.6 was released last month.
So, what you mean is that this issue is not a regular occurrence? Please let me know next time it happens, and, instead of killing the process, wait about 10 minutes - if Nexus unfreezes itself then, I already know what the problem might be.
PostPosted: Wed Aug 10, 2011 2:33 pm
Ok I'll do that
PostPosted: Tue Aug 16, 2011 10:49 am
I've had the crash I was talking about today. After hibernate, the nexus bar gets like a white rectangle and doesn't answer. I've waited like 15-20 minutes and it still didn't get better. So I finaly had to kill it and reopen it.
PostPosted: Tue Aug 16, 2011 5:21 pm
win 7 ultimate...Nexus never crashes for me :wink:
PostPosted: Tue Aug 16, 2011 7:05 pm
Cherrys, so apparently it's not what I was thinking it might be.
One very important question: does this happen *every single time* your PC returns from hibernation or only sometimes?
Also, next time it happens, open the Windows Task Manager in the Processes tab. Look for the nexus.exe process, how much percentage of the CPU is it using?
PostPosted: Tue Aug 16, 2011 7:12 pm
It used to be every single time, but since the update (I guess), not any more. I think I got my computer out of hibernation half a dozen time without any problem, and this morning it did it again, once.
Next time the problem occurs, I'll check the CPU use.
PostPosted: Wed Aug 17, 2011 1:32 pm
The problem occured again.
The CPU use is very low, like 3'176K,
I also copied the details of the failure, but it's in french... But in case it's of any help, here it is:
Description :
Un problème a provoqué l’arrêt de l’interaction de ce programme avec Windows.
Signature du problème :
Nom d’événement de problème: AppHangB1
Nom de l’application: Nexus.exe
Version de l’application: 11.6.0.968
Horodatage de l’application: 4e1382d9
Signature de blocage: c700
Type de blocage: 0
Version du système: 6.1.7601.2.1.0.256.1
Identificateur de paramètres régionaux: 4108
Signature de blocage supplém. 1: c70005686993a00553f254688cd1f3ca
Signature de blocage supplém. 2: 51d7
Signature de blocage supplém. 3: 51d794a297b89422e00b6a64fac1ea99
Signature de blocage supplém. 4: c700
Signature de blocage supplém. 5: c70005686993a00553f254688cd1f3ca
Signature de blocage supplém. 6: 51d7
Signature de blocage supplém. 7: 51d794a297b89422e00b6a64fac1ea99
Users browsing this forum: Amazon [Bot] and 164 guests
