 Post subject: remove text over icons
PostPosted: Sun Jul 31, 2011 8:03 am
The ability to remove the text that appears over the icons when yo have text below icons set to none would be good.
 Post subject: Re: remove text over icons
PostPosted: Sun Jul 31, 2011 8:52 am
You mean on the Shelf?
And then how would you identify all the similar icons (for instance, different text files on a folder-type tab all displaying the same generic icon)?
PostPosted: Mon Aug 01, 2011 5:49 pm
Yeah on the workshelf mate, I make my icons with text on them, like here,
Think it would be a nice feature.
On a side note, i have a number of winstep themes made now, i had no luck uploading them to the themes section here, but they can be found on Virtual customs site if any one is interested in them. :)
Users browsing this forum: Google [Bot] and 25 guests
