 Post subject: Hide dock via shortcut or hotkey?
PostPosted: Sat Jul 30, 2011 11:08 am
I've been trying out the Nexus Dock so far and I think it's almost exactly what I need, but I've been searching all over for the option to hide the dock. Most of the time I want the dock completely visible, but sometimes it will block other text or else show up during full-screen flash videos. I want a way so I can do either / or:
1. Press a hotkey to change the dock's status to autohide (or hide altogether), press again to change it back to always on.
2. click on a shortcut to change dock's status to autohide, click it again to change it back to always on.
Is it possible to do this somehow?
 Post subject: Re: Hide dock via shortcut or hotkey?
PostPosted: Sat Jul 30, 2011 6:32 pm
No, but you can hide the dock manually by double clicking the dock control icon, then bumping the screen edge to retrieve it.
PostPosted: Sat Jul 30, 2011 7:27 pm
Well I think a hotkey option is the way to go for future releases, but this is a pretty good stopgap measure, though it does mean I'll probably want to cram everything on one dock now.
PostPosted: Mon Mar 05, 2012 6:54 pm
I was bumping this to see if a hotkey option for hiding the dock might be possible for a future release or if it's not even on the radar.
PostPosted: Mon Mar 05, 2012 7:33 pm
v12.2, which is going to be released this week, will enable you to optionally use the activation hotkeys as 'toggles', i.e.; use once to show, use again to bring forward then hide.
PostPosted: Mon Mar 05, 2012 9:04 pm
That's awesome, thanks for such great support.
Users browsing this forum: No registered users and 50 guests
