 Post subject: problem with the "start menu" internal command
PostPosted: Mon Jul 25, 2011 4:42 pm
Nexus version 11.6
I add a "Start Menu" button from internal command on my dock.
When it is launched, the window of start menu would disappear quickly
after I moving the mouse. It prevented me from accessing the start menu.
I don't know why. It's normal in the previous version.
 Post subject: Re: problem with the "start menu" internal command
PostPosted: Mon Jul 25, 2011 4:56 pm
That will happen if something 'steals' the focus from the Start Menu as you move the mouse into it.
What version of Windows are you running?
PostPosted: Mon Aug 01, 2011 4:03 am
I use Win 7 64bit.
PostPosted: Mon Aug 01, 2011 4:09 am
Open Nexus Preferences, go to the Behavior tab, click the Advanced button and set the popup delay to maximum (long) to see if that makes a difference...
PostPosted: Thu Aug 04, 2011 7:24 am
I change the setting from minimum to 250ms and it works fine enough for me.
Thanks a lot.
PostPosted: Thu Aug 04, 2011 11:34 pm
Not a problem. This has been fixed in the next release. :D
Users browsing this forum: Google [Bot] and 26 guests
