 Post subject: Icon graphic problem
PostPosted: Sun Jul 10, 2011 12:55 pm
Hi,
I am using latest version of Nexus dock with zoom effect and bouncing icons when launching apps. Zoom works fine on roll over.
But the problem is when I release the mouse over an icon it jumps up and down but it leaves the weird graphic on the left and right side. (I am guessing it tries to do the roll over effect as well while jumping because the mouse is over it).
If I release the mouse over an icon and remove it fast, then everything looks normal without any weird graphics.
Anyway, just thought I'd report this.
TS
 Post subject: Re: Icon graphic problem
PostPosted: Sun Jul 10, 2011 1:03 pm
Ah, I see the problem, thanks. :D
For now you can work around this by going to the Effects tab in Preferences, click on the Effect Settings button for the Zoom effect, and reduce the magnitude of the effect by one notch.
Users browsing this forum: GPT [Bot] and 37 guests
