 Post subject: Nexus Dock 11.5 and system tray behavior
PostPosted: Sat Jun 25, 2011 7:42 am
After updating to version 11.5, I have some problems with the system tray. When I mouse over a tray item, the label says only "System Tray". I have difficulty getting the right mouse button context menu to come up. I use zoom effect. When I right-click on tray item, nothing happens except it un-zooms. Then, I have to right-click again without moving the mouse (to keep it from zooming again) to get the context menu. Sometimes I can double-right-click and get the context menu as well. With version 11.2 I have no problems with system tray item labels, or right-click context menus.
Thanks again for all your hard work. Nexus Dock is awesome!
 Post subject: Re: Nexus Dock 11.5 and system tray behavior
PostPosted: Sat Jun 25, 2011 8:23 am
Unfortunately it's a bug with the Zoom effect. :cry: I changed something on it in v11.5 and forgot to update the code that 'makes up' for the zoomed size in the grouped tray icons.
I've fixed it already here, but for now you'll have to wait for the next maintenance release, use another mouse over effect, or un-group tray icons.
PostPosted: Thu Jul 21, 2011 1:15 am
Well, it's a bit easier with version 11.6. It still seems much more sensitive than it used to be. When I mouse over an icon in the tray, I have to move the mouse around the icon until I see the correct label. If I just right-click on it, as I used to, most often the context menu for an adjacent icon pops up.
 Post subject: Re: Nexus Dock 11.5 and 11.6 system tray behavior
PostPosted: Fri Jul 22, 2011 2:38 am
I forgot to mention, I have the zoom set at 75%. If I set it at 100%, everything is fine, but then part of the icons are zoomed off the screen.
PostPosted: Fri Jul 22, 2011 7:25 am
I've solved the problem for now by going to full (100%) zoom and positioning the dock slightly lower with respect to top screen edge. I think I will just keep it this way. Thanks again for this amazing piece of software.
Users browsing this forum: Google [Bot], GPT [Bot] and 68 guests
