 Post subject: Unable to remove separator
PostPosted: Fri Jun 24, 2011 1:28 am
Hi,
I am using Ultimate 11.2 and having a bit of a problem in trying to remove separators from my dock. When I use the context menu (right-click), no Nexus options are indicated. Am I missing something?
Thanks in advance,
Jake
 Post subject: Re: Unable to remove separator
PostPosted: Fri Jun 24, 2011 1:56 am
Hi Jake!
Can you please post a screenshot displaying the dock with the separators you want to remove? Also, right click is working properly for all the other dock shortcuts, right?
Users browsing this forum: GPT [Bot], Majestic-12 [Bot] and 39 guests
