 Post subject: Create "Dropdown" Lists in Dock-Nexus
PostPosted: Mon Jun 06, 2011 4:49 pm
Hy,
I just discovered that one can create dropdown lists within the Dock-Nexus by just stacking the icons.
But how can I disable (or skin) this tiny green triangle pointing out that there exist dropdown stacks? Everything is looking great of Nexus, except of this! I'd like to disable it fully, because I know myself where I stacked apps.
Further: how can I customize the showing of the stacked items? I'd like to show the hole stack when hovering over the primary (topmost) icon...
Thanks for you help
 Post subject: Re: Create "Dropdown" Lists in Dock-Nexus
PostPosted: Mon Jun 06, 2011 7:02 pm
What version of Nexus Ultimate are you running?
PostPosted: Mon Jun 06, 2011 7:24 pm
The newest one of course, I think 11.2
PostPosted: Mon Jun 06, 2011 7:49 pm
The upcoming v11.5 changes the default green sub-dock indicator arrows to something a lot more pleasing to the eye (check the vertical dock on the right):
If you're a registered Nexus Ultimate user you can request access to the Beta Discussion section of this forums and install the v11.5 preview, but you will need to send me a PM with the email address and/or name you used to register Nexus Ultimate, since I don't recognize the one you are currently using.
PostPosted: Mon Jun 06, 2011 10:06 pm
Looks really great!
Anyway I'd appreciate to greate stacked apps with optional disabled "arrow" icon.
As I'm a very patient person I'm just going to wait for the next release. Think I am not the right person for beta testing...
But really looking forward to it!
Cheers and thanks a lot
Users browsing this forum: Amazon [Bot], Google [Bot] and 76 guests
