 Post subject: Setting not saving after restart
PostPosted: Sat Apr 16, 2011 2:36 pm
Windows 7 64bit Enterprise (Ultimate)
When I unchecked "Keep this dock visible when pressing Win-D" the nexus dock works perfectly the way I like it.
Funny thing is though that this setting reverts back to being checked after nexus restarts, either manually or via a computer restart.
Right now every time i boot up i have to uncheck the setting.
I tried reinstalling and it also did this on a fresh install of 11.2 as well.
No other setting seems to have this issue.
 Post subject: Re: Setting not saving after restart
PostPosted: Sat Apr 16, 2011 3:26 pm
Gotcha. Fixed for next release, sorry about that.
PostPosted: Sat Apr 16, 2011 8:40 pm
Thanks for such a quick response your support is as good as your product
Users browsing this forum: Amazon [Bot] and 55 guests
