 Post subject: Taskbar Delay
PostPosted: Thu Mar 24, 2011 8:42 pm
Hi, there. I'm using this great program and I'm very happy with it. However I'm having a problem with the Nexus taskbar icons. It takes a lot of time to load new icons into de taskbar (like 1 minute). For instance I have many programs that minimize into the taskbar, but after I minimize them they don't show automatically, as i said before it takes like a minute to show. Any solution for this? Thanks in advance.
 Post subject: Re: Taskbar Delay
PostPosted: Thu Mar 24, 2011 9:28 pm
Sorry, I don't understand what you are trying to explain...
I'm assuming you are running Nexus and not Winstep Xtreme, by the way:
After you minimize an application it takes a minute to show where? In the Windows taskbar? In the Nexus dock?
Also, applications will show in the Windows taskbar (or even in the Nexus list of running applications, if you enabled that) even when they are not minimized, which is why I find what you said pretty confusing, sorry.
PostPosted: Thu Mar 24, 2011 9:36 pm
First of all, thanks for the quick reply, Sorry I did not explain myself very well. The problem comes in The Nexus dock Taskbar. There are some programs that give you the the possibility to minimize to the tray. The problem is when I minimize them to the Nexus dock taskbar icons, it takes like a minute to appear in the nexus trayicons. the problem also is present when you connect a external drive like a pendrive. The Remove icon takes like a minute to appear in the nexus task bar. Hope I made myself a little more clear this time. Thanks.
PostPosted: Fri Mar 25, 2011 1:54 am
Ah, gotcha now.
What version of Windows are you running?
What version of Nexus?
Do you have the 'Always show all system tray icons' setting enabled in Nexus?
PostPosted: Sun Mar 27, 2011 6:18 pm
The versión of nexus is 11.2 My system is windows 7 64 bits professional, and the option of showing all the taskbar buttons is enabled. Thanks.
Users browsing this forum: Apple [Bot] and 130 guests
