 Post subject: WinStep theme thumbnails not showing
PostPosted: Thu Feb 24, 2011 2:55 pm
Hello everyone :-)
as you can see in the attached screenshot, the workshelf is only showing the standard icon for an image file, instead of the thumbnails for the themes.
Actually i am not sure how it happened, but i wonder if anyone can help me to restore the thumbnail display again , without loosin all my settings ?
thanks in advance :-)
Cytraveler
File comment: screenshot showing the problem...
 Post subject: Re: WinStep theme thumbnails not showing
PostPosted: Thu Feb 24, 2011 3:31 pm
Open WorkShelf Preferences -> Advanced tab -> Advanced Button
Is the 'Show document, image and video files as thumbnails' setting enabled?
PostPosted: Thu Feb 24, 2011 4:32 pm
WOW ! 1000 thanks for your fast reply Jorge :-)
... now that was a quick fix, the problem is solved !
I was thinkin that option was only meant for the case that i have a shelf pointing to a folder with my own images or videos, not for the themes as well...
... to be honest i should have tried that ;-)
Hey i just love your program !
Thanks again Jorge.
Cytraveler
Users browsing this forum: Google [Bot] and 12 guests
