 Post subject: copyto moveto
PostPosted: Fri Feb 18, 2011 4:31 pm
the copyto and moveto for workshelf has been giving me a problem. moveto right click an item attempt to drill down to where i want the item moved to and the move to dialog closes out, and move the item but when i do a search for it it's nowhere to be found. copyto now same behavior with the exception of when i try to drill down to where i want the item it actually copies it and i can find it in a search, it however just copies it to the parrent drive instead of the folder i'm trying to drill down to. i've had this prob for quite awhile, and just have been dealing with it. any ideas would be great.
 Post subject: Re: copyto moveto
PostPosted: Thu Feb 24, 2011 4:21 pm
any idea on the copyto moveto issue for workshelf?
Users browsing this forum: Google [Bot] and 70 guests
