 Post subject: Hotspot themes in Winstep Xtreme?
PostPosted: Tue Feb 01, 2011 4:31 am
i was wondering if there is a way to change theme of Hotspots in Winstep Xtreme? I would like to better see the Hotspots when i activate them via a hotkey on top of other applications (Fig. 1). Basically, i would like to be able to change the transparency of the Hotspot, and change the color of the active menu bar (such as the one that says (Empty) in Fig.1). Is there a way to do something like that?
thanks!
Fig. 1
 Post subject: Re: Hotspot themes in Winstep Xtreme?
PostPosted: Tue Feb 01, 2011 5:05 am
Go to the Themes tab of NextSTART Preferences and check the 'Enable Vista Glass blur' setting. Do the same in the Themes tab of WorkShelf Preferences.
Users browsing this forum: Google [Bot] and 35 guests
