 Post subject: Configuration file for dock items?
PostPosted: Sun Jan 16, 2011 11:41 am
Hello,
is there some kind of file where all the dock items information (path, icons, launch options etc.) are stored? I want to change some icons from time to time, but using rightclick, change icon and so on is tedious, so I thought I could do this with e.g. RegEx.
Thanks in advance.
 Post subject: Re: Configuration file for dock items?
PostPosted: Sun Jan 16, 2011 2:18 pm
Settings are stored in the Windows Registry, but you shouldn't change them directly as this by-passes the GUI range checks and could cause the application to crash on startup.
To quickly change an icon, all you need to do is drag & drop a .ICO, .PNG or .TIF image over the icon in the dock you want to change. That simple. :D
PostPosted: Sun Jan 16, 2011 7:10 pm
Oh, thanks! Didn't knew it works with drag and drop.
Users browsing this forum: Amazon [Bot] and 53 guests
