 Post subject: RE: problem with dock items
PostPosted: Thu Nov 18, 2010 9:21 pm
Hi,
I have some problems with my top nexus dock items. When I try to add new items on the dock, it created only blank space without the new item appear. Left mouse, nothing happens. When I right click on the blank, it show the "Dock property" instead of "Dock entry property".
I tried to view the dock property and it appears that it still calculated those invisible items as dock items (as I now have 22 items but only 19 showing).
I would highly appreciate your help in this matter.
Moreover, if in the dock preference, there would be a feature to manage all the current dock items, it would be much better IMO.
Thank you in advance :)
 Post subject: Re: RE: problem with dock items
PostPosted: Fri Nov 19, 2010 2:43 am
Weird, sounds like your dock is somehow corrupted.
Open WorkShelf Preferences, Advanced tab, and make a Backup of WorkShelf settings, then send the file to the Winstep support address so I can have a look at it.
PostPosted: Fri Nov 19, 2010 10:56 am
I sent the file to the support email.
thank you for your support.
PostPosted: Mon Nov 22, 2010 7:05 pm
sorry, is there someone out there :(
Users browsing this forum: Apple [Bot], DuckDuckGo [Bot] and 43 guests
