 Post subject: Unknown Folder
PostPosted: Sat Oct 23, 2010 8:12 pm
Jorge,
I get a registry error because Nexus(free) appears to make a reference to:
"C:\Users\Public\Documents\Winstep\Themes\OPENSTEP_EUI"
which appears to be a bitmap directory. What is it, and why is Nexus looking for it? Is there a setting that I can set that will reference a real folder?
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Unknown Folder
PostPosted: Sat Oct 23, 2010 8:40 pm
What do you mean by registry error? You actually get an error dialog?
OPENSTEP_EUI is one of the themes that ships with Winstep Xtreme. Don't forget that Nexus is a sub-set of WorkShelf in Xtreme, which might explain why you are seing a reference to that particular theme folder.
PostPosted: Sun Oct 24, 2010 12:27 am
Jorge,
No error dialog. I see the error in a registry scan. It sees it as a registry entry pointing to a non-existing file/folder. I'm a bit of a neat-freak. I don't like to have loose ends.
I created the empty folder just to make the registry scan happy.
Sorry for the misunderstanding.
Thanks,
Grouch
Windows 10 Pro[x64]
Users browsing this forum: Google [Bot] and 34 guests
