 Post subject: System tray icon
PostPosted: Tue Mar 15, 2011 1:01 pm
Jorge,
What happened to the System tray icon? It's just an ugly solid-grey diamond-shaped thing. Is that an enhancement?
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: System tray icon
PostPosted: Tue Mar 15, 2011 4:10 pm
Err... yes?
The old Nexus icon looked a mess at 16x16.
PostPosted: Tue Mar 15, 2011 7:31 pm
Hi!
Just updated to 11.2 and I have the same problem here!
Nexus icon in dock turned gray also in Start menu folder - when we open it there are two gray icons (Nexus User Guide and Nexus).
Another issue: Now, when I move mouse along the bar icons seem to shake and it's not presenting a fluid movement.
Running Windows 7/x64
Anny suggestions?
Thank you Jorge Coelho and other friends
PostPosted: Tue Mar 15, 2011 7:37 pm
The gray diamond shaped icon is now used when displaying the Nexus icon at 16x16 size. The old version was a resized version of the larger 128x128 icon and looked a mess at 16x16 sizes.
Any chance of a screenshot (just press the PRTSCR key, which captures a snapshot of your desktop into the clipboard, then paste it into any image program) or, even, a video? :-)
Users browsing this forum: No registered users and 36 guests
