 Post subject: Question about showing running apps in Nexus dock
PostPosted: Fri Oct 15, 2010 4:14 pm
Hello! I have Nexus Ultimate 10.7 which has the option to show running applications in the dock, however I cannot get them to display. I have "show running applications as windows thumbnails" checked. Is there some other option that needs to be enabled? Thanks!
 Post subject: Re: Question about showing running apps in Nexus dock
PostPosted: Fri Oct 15, 2010 5:00 pm
Did you enable 'Show running applications in this dock' in the Effects tab? You can also right click any dock icon -> Insert New Item -> Show running applications...
PostPosted: Fri Oct 15, 2010 5:30 pm
Ah, that takes care of it. By the way, is it correct that in Nexus Ultimate 10.9 the running apps icons show live previews as in the Windows 7 Superbar?
PostPosted: Fri Oct 15, 2010 9:50 pm
Yes. Check this video demo here: :D
Users browsing this forum: Google [Bot] and 73 guests
