 Post subject: Modules Z-Order Issue
PostPosted: Sat Oct 09, 2010 6:01 pm
Had a weird occurance this morning. Whilst playing around I managed to reset the weather module in such a way that it never pops up over the active window when I click on it.
I've played with every z-order setting. The other modules I'm using work fine.
Any ideas?
John
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
 Post subject: Re: Modules Z-Order Issue
PostPosted: Sat Oct 09, 2010 7:29 pm
Just to be sure: did you right the Weather Module -> Z-Order -> Normal?
Have you tried closing and re-opening the module?
PostPosted: Sat Oct 09, 2010 9:17 pm
Just got back in...
It appears that a reboot (the comp was shut off for a while) has cleared it up. <shrug>
As for Z-Order: Normal, that was the first thing I tried
Gotta say, the more I play with your creation, the more impressed I am. Thanks for putting it together.
Now to figure out if I should create custom menues, docks, shelves, or all three...
JS
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
PostPosted: Sat Oct 09, 2010 9:20 pm
I vote for all three. :D
PostPosted: Thu Oct 14, 2010 3:05 am
I like the way you think :mrgreen:
Off to play
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
Users browsing this forum: DuckDuckGo [Bot] and 88 guests
