 Post subject: The Nexus taskbar
PostPosted: Tue Sep 21, 2010 2:26 pm
First things first, this program is amazing! I love its features and such, especially the function to completely remove the original windows taskbar. I can't wait until the taskbar and start bar become one, like windows 7 taskbar. This is a lot better looking :P
anyway if you look at the attachment you will noticed I have circled 3 items, is it possible to place these files into the little blue circle? I dislike looking at them.
Thank you again. [:
:edit:
I have found an option in the preferences to fix this. i grouped them up [:
awesome program.
File comment: SCREENIE
 Post subject: Re: The Nexus taskbar
PostPosted: Tue Sep 21, 2010 4:00 pm
You need to right-click on windows taskbar and choose Properties, then Taskbar/Customize.
If you have windows taskbar hidden, you can click on Start Menu button of Nexus, then right-click on the Start Menu pop-up. I hope this is what you are asking for.
Users browsing this forum: DuckDuckGo [Bot] and 87 guests
