 Post subject: Need help to change wallpaper in winstep themes
PostPosted: Mon Sep 13, 2010 5:02 pm
Hi all
i'm french and glad to use WS xtreme
How can I change the wallpaper.jpg in themes
example, Dragon Xtreme theme and put a different wallpaper (background)
many thx
13002
 Post subject: Re: Need help to change wallpaper in winstep themes
PostPosted: Mon Sep 13, 2010 6:59 pm
Just apply the wallpaper as you normally would.
If what you want is to associate a permanent different wallpaper to that theme, on the other hand, then select the theme in the Themes tab, click the open folder button, and replace the wallpaper.jpg bitmap in the theme folder.
PostPosted: Mon Sep 13, 2010 9:53 pm
Also, if you want to keep the same wallpaper even if you change themes, go to the Workshelf Preferences dialog (CTRL - F11), select the General tab and on the bottom right put a check in the box for "Prevent themes from changing your current wallpaper"
PostPosted: Tue Sep 14, 2010 1:37 pm
Thx to winstep and DanDaBear
so long
Users browsing this forum: No registered users and 47 guests
