 Post subject: In-shelf tooltips Global Tab in Preferences
PostPosted: Sat Sep 04, 2010 7:04 am
I'm using Xtreme and the attached Tip of the Day regarding In-shelf tooltips came up. So where is the Global Tab in Preferences?
[youtube]http://www.youtube.com/KenInGilbert[/youtube]
Laptop: Windows 7 Pro 64bit, Dell M6500 Precision Workstation
Intel i7-980XM Extreme 2.13Ghz 8MB cache, 16GB DDR3 RAM 1333Mhz, 1GB NVIDIA Quadro FX 3800M Graphics, 17” WUXGA RGBLED LCD Panel w/webcam, 500GB 7200rpm HD
 Post subject: Re: In-shelf tooltips Global Tab in Preferences
PostPosted: Sat Sep 04, 2010 9:24 am
Sounds like maybe you're looking for this (?):
"Advanced" tab, then "Advanced" button in the lower right corner underneath "Miscellaneous" header, then check or uncheck "Show balloon information tooltips on mouse over after a short delay". Is that it?
PostPosted: Sat Sep 04, 2010 12:38 pm
Ah, some of the text in the tips is outdated, sorry. Global tab in the old UI would be the General tab in the new UI. There is not attachment in your message, though?
PostPosted: Sat Sep 04, 2010 11:30 pm
Screen shot now attached, I didn't see that the bmp format wasn't supported.
File comment: screen shot
PostPosted: Sun Sep 05, 2010 12:55 am
Well, as I said, the tips file hasn't been revisited in a while.
That tip refers to the balloon tooltip, and you can now find the setting required to turn in off in Preferences -> Advanced -> Misc.Advanced dialog.
Users browsing this forum: No registered users and 54 guests
