 Post subject: 2 wishes for Nexus Ultimate
PostPosted: Tue Aug 31, 2010 4:27 pm
For Nexus Ultimate:
1. A volume control for Nexus sounds in Preferences within the Sounds tab. Ultimate sounds are much louder than Microsoft system sounds or the sounds in any of my apps.
2. A redo of the hot zones for the tabs in Dock Properties. At first I thought that Nexus Ultimate was broken because clicking on non-active tabs in Dock Properties didn't activate them. Then I learned by trial and error that if I clicked a non-active tab just below the text, I could activate the tab.
Other than that, a great product!
 Post subject: Re: 2 wishes for Nexus Ultimate
PostPosted: Tue Aug 31, 2010 4:54 pm
1. If you are running Vista or Windows 7, you can do that yourself: the Windows mixer has a per-application slider. :D Otherwise, you will have to re-sample the sound files themselves or make your own set, sorry. :(
2. What are your Windows DPI settings?
PostPosted: Wed Sep 01, 2010 12:44 pm
Thanks for the quick reply.
I'm running XP Pro SP3, so I guess I'll work my way through all the Nexus sound files and reduce their amplitude myself with Audacity.
I've got my display set to 120dpi. I tried 96dpi when I trial'ed Windowblinds a couple of years ago and decided that 120dpi is the only way to go with my laptop LCD display.
Users browsing this forum: No registered users and 280 guests
