 Post subject: sfc /scannow does not work with Nexstart loaded.
PostPosted: Sun May 15, 2011 3:17 pm
I was trying to run sfc /scannow with a command prompt and it would say "Windows resource protection could not start the repair service". I booted into safe mode, and it worked fine. I booted back into windows noemal mode, and decided to start shutting down programs to see which one was causing the problem, and it was Nextstart.
Any ideas? This is Win 7 64, and running version 11.2.
 Post subject: Re: sfc /scannow does not work with Nexstart loaded.
PostPosted: Sun May 15, 2011 6:13 pm
Possibly because of something to do with the 64 bit vs 32 bit system and automatic Registry and file system re-direction...
Where are you launching the Command Prompt from? NextSTART or the real Windows Start Menu? Is it the 32 bit or the 64 bit version?
PostPosted: Sun May 15, 2011 7:34 pm
I am launching it from my shelf.
PostPosted: Sun May 15, 2011 7:58 pm
That's probably where the issue lies: the Shelf is a 32 bit application and will thus launch the 32 bit version of CMD.exe. The 32 bit Command Prompt is then unable to launch the 64 bit version of SFC.
The Windows 32 bit automatic file system re-direction in 64 bit systems works most of the time, but it's also a bit of a kludge.
Try launching CMD from the Windows Start Menu (press the WIN key).
PostPosted: Mon May 16, 2011 11:50 pm
This works, and you are correct sir!!
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 49 guests
