 Post subject: Security option!
PostPosted: Sat Aug 07, 2010 2:53 am
is there any security option?
like password for changing preference
disable changing any shortcut (add,delete) for ordinary user
and is there any way to disable "show container/browse container" from right click? < this is the real problem
lastly, it seems like shortcut are ordered automatically. can i order it myself?
i really hope there is security option though, for next update maybe?
thanks!
 Post subject: Re: Security option!
PostPosted: Sat Aug 07, 2010 4:38 am
Are you running some kind of Internet Cafe or LAN house to need those lock-in/security options? :D
Shortcuts are only ordered automatically on non-regular Shelf tabs, i.e.; tabs that display the contents of folders or virtual folders (e.g; Desktop and Control Panel tabs).
Users browsing this forum: No registered users and 55 guests
