 Post subject: Custom clock sounds?
PostPosted: Thu Aug 05, 2010 9:04 pm
I would like to use my own clock chime sounds with the clock, can I do that?
 Post subject: Re: Custom clock sounds?
PostPosted: Thu Aug 05, 2010 10:01 pm
Yes. Open Preferences and go to the Sounds tab. Click on Clock Chime and then Browse to select your sound. Save the sound scheme with the same name if you want the sounds to remain when you switch themes.
PostPosted: Thu Aug 05, 2010 11:01 pm
Thanks I just found it. I didn't realize there were 2 places with options. I was looking at the wrong one. Thanks! Got the program yesterday from giveawayoftheday.com and love it!
Users browsing this forum: Amazon [Bot], Google [Bot] and 74 guests
