 Post subject: Controling the sound
PostPosted: Wed Aug 04, 2010 1:38 pm
I have just installed the dock and am very pleased with it. The one thing that I am not thrilled with is that the volume of the sound effects is too loud. Is there a way to lower the volume without lowering the master volume of my computer?
Jere
 Post subject: Re: Controling the sound
PostPosted: Wed Aug 04, 2010 1:56 pm
Assuming you don't want to turn the sounds off completely, on my XP Ultimate machine with Realtek HD Audio Manager, I have a Volume Control that allows me to set the Speaker (master?) volume, Windows sounds and WS sounds. Sounds levels can be set equal to or lower than the Speaker volume.
PostPosted: Wed Aug 04, 2010 2:03 pm
And under Vista/Win 7 you can set the sound level on a per-application base.
Users browsing this forum: No registered users and 55 guests
