 Post subject: Skinning Both the Shelf and Nexus Dock at same time
PostPosted: Wed Jul 28, 2010 9:37 am
When I apply themes, it skins the icons on the nexus dock but don,t actually skin the dock itself, it does fully skin the shelf.
I know that I must have messed with a setting somewhere, because it skins both the shelf and the dock on my laptop ok, just not my desktop. I just can't find the setting, and I have put so much work into the dock, I can't afford to lose my work and do a reset. :oops:
EDIT: I just tried to reset just the settings, but that failed to fix the problem. :(
Another EDIT: I fixed the problem by simply re-creating a new dock and dragging my stuff there! :lol: Phewwwwww
 Post subject: Re: Skinning Both the Shelf and Nexus Dock at same time
PostPosted: Wed Jul 28, 2010 10:27 am
Hehe, glad to know you managed to fix the problem.
You probably locked the theme for your dock, which prevents it from being changed when you make a global theme change in the Themes tab of Preferences.
If it happens again, right click on any icon in the dock -> Nexus -> Appearance and Sounds -> Unlock Dock Theme.
You can also change the theme for an individual dock, even when locked, in the Themes tab of the Dock Properties dialog for that dock.
PostPosted: Wed Jul 28, 2010 11:49 am
Thanks, that is exactly what happened and I will always be watchful of those settings, I thought the only settings were in the menus, boy was I wrong! :lol:
I am loving this software more and more, it is already making my work much easier, this is day 3 and I am learning my way around pretty well.
Users browsing this forum: DuckDuckGo [Bot] and 87 guests
