 Post subject: hide dock automaticaly
PostPosted: Mon Jul 26, 2010 6:52 pm
Hi all and Winstep team,
I just buy NEXUS and I don't find issue for my problem. Can you help me for that...
I want to activate and desactivate viewing dock and Rayon with my mouse and only my move mouse. Not the click.
For showing dock and Rayon ok but for hide automaticaly I must clicking for hide these always.
I all testing and dock run and hide normaly without click but only if program turn in full screen. When I on the desktop dock hide no automaticaly.
Obligatory launch program for hidden dock and Rayon...
thank a lot for all,
 Post subject: Re: hide dock automaticaly
PostPosted: Mon Jul 26, 2010 9:37 pm
Docks and the Shelf (Rayon) will hide automatically provided the 'auto-hide' setting is enabled *and* another window has the focus.
If I understood correctly, this last item is the problem for you. Open WorkShelf Préférences -> Autres réglages -> Divers, Autres réglages -> clear 'cacher ou fermer automatiquement si d'autres fenêtres...'
PostPosted: Tue Jul 27, 2010 6:22 pm
Thank you for reply.
I already checked this option.this option not run in desktop window.
AND
for Rayon, It never automaticaly hide. In desktop and when other window is in first plan. This is more awkward
PostPosted: Tue Jul 27, 2010 6:35 pm
Can you post a screenshot of your desktop here, with the Shelf/Rayon Properties dialog open in the Behavior/Comportement tab, please?
PostPosted: Tue Jul 27, 2010 10:02 pm
Sure...
File comment: screenshoot desktop with nexus rayon and parameter
PostPosted: Tue Aug 03, 2010 7:08 pm
no issues ?
PostPosted: Tue Aug 03, 2010 8:33 pm
Ooops, sorry, and thanks for bringing to my attention that this issue had been left 'hanging'.
I've just tried your settings here (including the inverted Shelf) and everything is working as it should.
There is only one cause I can think of at the moment: instead of expanding the Shelf/Rayon by clicking on the tab header, you are perhaps clicking on the right mini-tab?
When you expand the Shelf via the right mini-tab, this is considered a deliberate 'manual' expansion and the Shelf will remain open until you click again on the right mini-tab to collapse it.
Apart from this, did you change the Animation speed settings or did you disable Animations completely in the General tab of Preferences?
Users browsing this forum: No registered users and 47 guests
