 Post subject: Callouts
PostPosted: Mon Jul 26, 2010 2:24 pm
Another newby question...Is there a way to disable the callouts?
 Post subject: Re: Callouts
PostPosted: Mon Jul 26, 2010 4:25 pm
Errr, not sure I understand. What do you mean by 'callout'?
PostPosted: Mon Jul 26, 2010 4:35 pm
When my curser hovers over and object and stays there for a second a callout pops up with a description of the item. Can I disable that?
PostPosted: Mon Jul 26, 2010 4:37 pm
Ah, we call them 'Balloon tooltips'. You can disable them, but first I need to know if you are running Nexus or Winstep Xtreme.
PostPosted: Mon Jul 26, 2010 5:51 pm
I'm running Winstep Xtreme.
PostPosted: Mon Jul 26, 2010 5:55 pm
Ok, in that case, open WorkShelf Preferences -> Advanced -> Misc.Advanced button -> clear the 'Show balloon information tooltips...' check box.
Note that by disabling balloon tooltips you will also not get the information presented in them on mouse over by modules in your docks/Shelf (e.g.; weather 5 day forecast, number of items in the Recycle bin and their size, etc...).
PostPosted: Mon Jul 26, 2010 8:42 pm
Perfect..I knew it had to be somewhere.
Great product! I can't believe I'm just finding out about this. You'll probably get a few more questions from me.
Thanks for the help!
Users browsing this forum: DuckDuckGo [Bot] and 87 guests
