 Post subject: Problem with recycle bin
PostPosted: Sat Jul 10, 2010 6:54 pm
Hello,
Using free version of Nexus (10.04.0904)under XP SP3, I have trouble with recycle bin. Double-click on the bin icon open "My computer". I have tried "Module" and "Internal Command", and result is the same.
Thank you for your help
Best regards
Philippe
 Post subject: Re: Problem with recycle bin
PostPosted: Sat Jul 10, 2010 7:11 pm
Not a problem with Nexus itself, though - working fine under XP SP3 here, just tested it again.
Are you using a 3rd party Recycle Bin Manager or do you have any software installed that does something with the Windows Recycle Bin?
PostPosted: Sat Jul 10, 2010 7:43 pm
Hello,
Thank you for your reply.
Before Nexus, I was using RocketDock but I have completely desintalled this software.
With Nexus, bin property window is correct. Only opening bin is bad.
I am going to re-install Nexus
Best regards
Philippe
PostPosted: Sat Jul 10, 2010 8:14 pm
I'm pretty sure you won't solve the problem by re-installing Nexus.
You installed something previously or did something that damaged the Recycle Bin entries in the Windows Registry.
Please read this:
http://www.msfn.org/board/topic/37104-r ... ktop-icon/
PostPosted: Sun Jul 11, 2010 7:33 am
Hello,
Base register was certainly corrupted. Since I made a registry restoration, it is working fine.
Have a good day
Philippe
Users browsing this forum: Apple [Bot] and 167 guests
