 Post subject: Splash screen
PostPosted: Wed Jun 30, 2010 9:22 am
Hi... i'm a satisfied user of nexus dock!
It's a very good work...
now i want to know if it's possible remove the "loading splash screen"!
I don't like it on my desktop when i start the system...
 Post subject: Re: Splash screen
PostPosted: Wed Jun 30, 2010 10:32 am
Yes, assuming you are running the latest version of Nexus: Preferences -> Advanced -> Advanced -> disable 'Show splash screen at startup'.
PostPosted: Wed Jun 30, 2010 2:21 pm
No... i haven't this option...
i'm running nexus dock free 10.4...
i'll try to download it again...
NOTHING... perhaps it is an option only for the completed version...
PostPosted: Wed Jun 30, 2010 5:24 pm
Oh. Ooops. Check the readme.txt inside the nexus.zip file. If the build number is less than 906, then download from here, please.
PostPosted: Wed Jun 30, 2010 6:49 pm
aaahhh... i have downloaded my version (904) from this site...
the link is not updated!
I'm downloading your link... thanks :-)
Users browsing this forum: Amazon [Bot], Apple [Bot] and 97 guests
