 Post subject: Nexus- 'Show Desktop' bug
PostPosted: Sun Jun 27, 2010 5:05 pm
Hello, I'm using Nexus for a long time. It's really useful but I noticed one, but very annoying bug.
When I click 'Show Desktop' button, Nexus is still visible on the dekstop, but when I do anything on the desktop (eg. delete a file, move an icon etc.) Menu Start, Nexus dissapears and the only visible element is the wallpaper :evil:
The only solution is ctrl + alt + del. Then everything backs to normal
Here is the movie which presents this:
Nexus- 'show desktop' bug
I tried to change settings but nothing helped
I use the latest version of Nexus and Windows 7 32-bit
 Post subject: Re: Nexus- 'Show Desktop' bug
PostPosted: Wed Jun 30, 2010 1:16 am
Dawidm,
I think what you're referring to is:
Nexus/Position & Behavior/Behavior/auto-hide after a short delay
Then Nexus/General/Auto-hide Delay
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Thu Jul 01, 2010 7:48 am
I know what he means. Problem is that the Show Desktop function raises the desktop window to the very top of the z-order, and tries to keep it there. This creates several z-order problems when you then switch from Nexus to the Desktop and vice-versa.
I'll see what I can do.
PostPosted: Fri Jul 02, 2010 9:26 am
@GROUCH - thx, but it didn't help ;)
@WINSTEP - OK, I'm waiting for any solution :)
Users browsing this forum: Apple [Bot] and 70 guests
