 Post subject: minimized windows
PostPosted: Sat Apr 01, 2006 10:51 pm
Is there a way to see the windows i have minimized on the nextstart taskbar? I am always having to quit nextstart to maximize them again. I have looked all over preferences but have not found anything. Thanks for help.
PostPosted: Sat Apr 01, 2006 10:59 pm
In the NS configuration menu, in the Startbar preferences section, make sure that the 'Tasklist' is checked to show.
If that's not what you're talking about...sorry :(
PostPosted: Sat Apr 01, 2006 11:12 pm
Thanks i have that checked, but i still do not see any window i have minimized except when i exit nextstart and see them on the xp taskbar. I am using winstep xtreme. Anyway thanks
PostPosted: Sun Apr 02, 2006 3:52 am
Open NextSTART Preferences, About tab, and report back the version you are using (lower right corner).
PostPosted: Sun Apr 02, 2006 8:23 pm
Hi, I am using Nextstart version 3.41 Thanks
PostPosted: Sun Apr 02, 2006 9:04 pm
Open NextSTART's Global Preferences tab and make a backup of your current NextSTART configuration. Then please email the resulting *.nbk file to me at support@winstep.net .
