 Post subject: Suggestion: Improvement of file browser UI...
PostPosted: Tue Jun 01, 2004 8:14 pm
I'm now used to using NextSTART's file browser, but it is a bit non-intuitive compared to other file browsers used on windows (and Linux). It's ok, but could it at least be made to be dragged larger? I have plenty of screen realestate yet the file browser is so small. Thanks.
PostPosted: Wed Jun 02, 2004 5:18 am
Not sure you realize this, but in Global Preferences, you can check the checkbox that says "Use Windows File Browser" and it will do exactly that.
Users browsing this forum: No registered users and 80 guests
