 Post subject: Check email 10.3
PostPosted: Fri Apr 02, 2010 11:10 am
Double clicking opens up another instance of Outlook when it is already running.
Can you change this behaviour so that any existing instance that is running is maximized?
PostPosted: Thu Apr 15, 2010 7:17 pm
You can change the behavior so that any existing instance is brought to the foreground: right click on the Email Checker Module -> Email Checker Settings -> Enable 'Do not launch multiple sessions'.
Users browsing this forum: Amazon [Bot], Google [Bot] and 33 guests
