 Post subject: Nexus won't start on boot up
PostPosted: Wed Apr 07, 2010 6:00 pm
My friend's free version of Nexus will not turn on when the computer boots up. It has to be manually started.
It's a on a Vista machine. I've tried for months to figure it out without finding a solution.
A relative had the same problem on XP, but I reinstalled it with the new version and it fixed the problem. Not on the Vista though.
PostPosted: Wed Apr 07, 2010 6:19 pm
There's a 'sticky' post about it at the top of this forum, blind bat! :wink:
Make sure you are running the latest version, click on Exit Nexus and then clear and set again the 'Run Nexus at startup' setting in the Exit confirmation dialog.
PostPosted: Wed Apr 07, 2010 6:20 pm
Oh, and how quickly people forgot about the 'Startup' folder in the Start Menu!
PostPosted: Wed Apr 07, 2010 11:52 pm
Thanks! It worked! Sorry for not looking more closely. I think I need to break out the red and white cane! :lol:
Users browsing this forum: Apple [Bot], Bing [Bot], nexter and 30 guests
